Adjustable Over-Voltage and Under-Voltage Protector Relay - Wapda Fluctuation Protector
Install this Adjustable Relay in your Homes, Shops, Offices and Save your Electronics Appliances from Electric Fluctuations and prevent from Burning.
Protect all your Electronics Items from Over-Voltage and Under-Voltage with this Automatic Adjustable Protector Relay.
** In case of Over-Voltage or Under-Voltage fault in Wapda Line, this Relay will automatically Turn OFF Power instantly and will save your Electronics Appliances from burning..
** When Voltage will became Normal, this Relay will Turn ON Power itself automatically.
** You can easily set the Over-Voltage and Under-Voltage Value yourself by simply pressing the Button.
Easy to Install, can be configured according to your needs of Voltage.
Shows accurate Voltage and Current on LCD.
- Rated voltage: 220V
- Rated current: 1A-63A (adjustable)
- Under-voltage action Switch-Off value: 210V-145V (adjustable)
- Over-voltage action Switch-Off value: 230V-300V (adjustable)
Price Rs 3000..
Cash on Delivery available to all Cities..
Contact: 03215260420
