get it to claim center you are free !
I can share my knowledge when bike is dead and donot give any signal of life.
1 - get the Plug out and kick the bike while plug is in contact with engine and cable is contacted to it.
2 - If you notice sparks in the Plug Chamber then you are clear from any issue from Electricals..
3 - Now Focus on Carb, close the tank fuel cork and drain it notice if there is any signs of water in it if there is water, then you catch the problem just drain it and open fuel cork give a choke and it will start.
4 - if no water is in cork, the make sure the feul line is actually sending fuel to carb or not.
I am very sure if you go through this cycle bike can not be missed and you will 100% catch waht is going wrong.
For electricals, if on point 1 if current is not comming, that means the CDI has gone bad or some problem with a lose connection as the bike is new, so it can be expected that any wiring connection may be lose.
I hope it helps you bro... but do go to claim center also.
