Salam. I have 2008 recently purchased.It gives smoke on cold start up continiously. After time smoke reduces. And totaly finish when i drive the car. But continious smoke when its standing on start position. I cannot tell exactly if it is blue or white.
Does the smoke smell? If yes, then the Valve seals have degraded.
Yes it does smell.Valve seals degraded means? How much expense and what to do
You'll have to change your Valve seals. Do a compression test first, both wet and dry. If compression is low, then a rebuild/swap is advised. If compression is ok, then you can change the Valve seals. Cost wise I have no idea.
How to do compression test? Or can u recomend me any mechanic
If its blue smoke then most likely its valve seals.
City??
Otherwise which smoke?
Otherwise it can be a blown head gasket.
The color of the smoke your car gives at cold start. If its blue.
Its white with greyaish touch
white smoke on cold winter morning is normal on startup
ya i guess not really a smoke. its kinda steam...
But is your car eating oil?
I recently changed the oil. Will have to deive more than 3000 km in order to look if its eating oil or not.
The smoke is white with greyish look. And it has petrol oil burning smell. But it disappears when i drive the car.
Does it throw water? If yes then it's a " water throwing engine" as per dealers- better than new
OK so you might have change your grade oil or engine oil just assuming? Whats the ODO reading is saying? how much is it driven? If you change the engine oil branding or grade oil. pehley keya use kar rahe they and abi konsa hai ?
Your car is running rich i guess. But not sure. was it properly tuned after the changing your engine oil?
Last night i observed two drops of water.
Odo meter is 150k almost. Mujhe nahi pata pehle kon sa oil use hua hai kiunke mainy abhi li hai car. Mainy zic oil 10 40 dalwaya hai.
