Finally, some work started.......good good progress. Bhai i have been identifying some things from time to time do take these as correctional critics. Minor adjustments and the thing taken care at this stage will imporve the looks as well as save money later.
1) remove that idiotic nozzle. if u want to use on petrol, than there is no need of this , its ruining the looks.
2) Please make it straight. i think this is not the original one at this moment u can make it straight even if new holes are required.
3 a & 3b). Ask your mechanic to make all the line straight and professionally corrected. i can see two brake valves. ask your mechanic why he has used if not required remove them.
4) the clutch cylinder should also be looked.
5) why the studs of right shocker mounts are bigger than the left ones.
