Some observations:
-central tunnel or spine has been cut open ahead of the gear lever. That must be closed and arc welded, and edges ground down with an electric grinder.
-the Research Octane Number of 83 means this is a low compression engine. Check with Nasir Shaikh for correct engine/valve parts
-you will need a correct body to floorpan rubber seal; again Nasir will have what you need.
