Thanks bro will give seller a call.
Sent from my GFIVE G10 mini using Tapatalk
Whats happening Waqar bhai?
more upgrades...
Ema make it ma monster niG*AA
Doomed Again [emoji12]
Sent from my HUAWEI G7-TL00 using Tapatalk
Becuase no good story starts with butterfly and sunshines..
Waah kya baat kerdi kya baat kerdi [emoji3]
nahi vicky bhai no smell but it heats up upto the level where one can't even touch it but now its fine its not getting that much hotter any more thank you once again for your reply
@vickytulla @seen4u and @rocketscience
@taha66 @vickytulla @seen4u
Waqar bhai isko b photoshop se edit kar k apni pic mey adjust kar leyn
awais is this your bike ? ye wohi wheels hai jo mene diye thay ?
This bike definitely needs a Hot rod engine... kamal lag rahi hai bike...
G Waqas bhai... rim ne bohat suit kia hai is pe and yes this bike needs a hot rod engine
@rocketscience @vickytulla guys received my heating pads but now the packing is in Chinese so couldn't under stand how to tell the electration to install it. Can u guys can help me in this matter.Your help will be appricated.
Sent from my INFINIX-X551 using Tapatalk
I also recieved it in a chinese packing... there is one red wire and one black(ground) wire...
Earth the ground wire or attach it to earth wire (mostly green) and connect the red wire to live(red or blue) wire which turns on only on "switch on" ..
Thanks will tell the electraction about it how is your experience so far.
Everything is written on the wraper.Right hand in English and Left hand in Chinese.
Agar phir b problem aa rahi hai to call kar lena sub samjha don ga
these days tempratur has droped extremely low... so the hands feel cold from out side.. so I used leather gloves and now once the gloves are warm then they stay warm even I switch the heaters off... very good experience so far...
So without gloves the grips didn't fell warm.
when temperature drops below 4'C you cannot face wind even if you put hands in fire... same case here hands are hot from inside but the chiling wind out side ... so to avoid that wind you will need gloves any ways or you will have blisstered hands out side and warm inside.. saying with totally my experience... ha ha ha haha I learned the hard way...
Yes these days it is v cold in isb to
Changing sprocket ratio to High speed Cruising instead of Heavy Acceleration for coming tour.
Are you guys buckling up ? @haroon1 @kashi.khan @salar.gilani @taha66 @jigzkorner @imranbhatti @angle82 @rocketscience @pirates
Removing the Bruttle Pick Sprocket 42'
35T rear
17t Front
