dear all i purchased Santro 2004 model last month its was working perfect on gas now when i m using it on petrol its race come back after some time. i got it checked by 2 mechanic they wash the sensors (where race wire plug in ) but problem is still there please guide me and suggest any good machnic in lahore
"race come back after some time" ............what does that mean....try to explain the prob in a better way
come back means when i push race it up and when release it it remains up (increase ) decreased to normal after some time 5 to 8 seconds.like during drive it envying e.g car is in 2nd gear i push race and need to push clutch for some hurdle race remains increased not decreased to normal
hope able to explain better please advise
Thanks
It means accelerator cable is fine.since issue was not on cng......tps / throttle body issue probably
i went yesterday to second machanic he washed all this circled area but problem is still there
had seen a same issue in a Chevrolet, don't know the reason though
May be its sensor issue.. Visit any Hyundai experts!Sent from my Windows Phone
Get the IAC valve changed. Problem will be resolved
get the iac valve cleaned.also check the tps output voltage.the mechanics clean the map sensor btw
It could be because of a sticky butterfly,get it checked.
Price
i am facing same issue hope you found solution let me know whats the issue so i can fix my issuejust spend 20k but still not fix this issue
i am also facing same problem in my santro
I have same problem, anyone has reliable and tested solution? The issue is not with CNG or Petrol, as it behaves same on any fuel.
change the map sensor,it is placed at the top of throttle...
I had the same problem. i got check my santro Air control valve its fixed to Throttle body. Valve's Jane(plastic sheet with tiny wholes for air control) found faulty i changed it now Santro race is normal
just get check ur Air control valve. i had the same problem just changed Valve Jan( Plastic sheet with wholes). Now every thing fine.
umairishaq check my above messages
Kya price tag hai iski? pura part change kia jai ya koi seal wagera change hogi iski?
