sorry guys it is fiat 480...
thanks adeel bhai.. from now on google is my best frnd...
here are the results
@ser_gtr
for this 48 bhp engine to go fast. i will have to come up with a massive gea box, i think two carts, one accomodating the engine and the other gear box and me on the the top of the tranny...lolz
FIAT 480
MAX POWER AT ENGINE CRANKSHAFT (kW): 35.52 (48 hp) at 2600 engine r/min
MAX POWER AT PTO SHAFT (kW): 31.7kW (42.5 hp) at 650 r/min at 2600 engine r/min,
MAX POWER AT DRAWBAR (kW): 27.6 (37 hp) at 2,600 engine r/min.
MAX CRANKSHAFT TORQUE: (Nm): 153 at 1,600 engine r/min.
MAX DRAWBAR PULL (kN) : 23,4 at 3,2 km/h on 14.9 x 28 tyres when tractor weighted to 3,540 kg.
ENGINE: Fiat 8035, cylinders=3, Bore=95 mm, Stroke=110 mm, Displacement=2,339 cm3, Compression ratio=17:1.
TRANSMISSION: Type=constant/synchro.
STANDARD SPEEDS: Forward=1.87, 2.82, 4.13, 5.33, 8.74, 10.14, 14.85, 19.19 km/h, Reverse=2.69, 9.69 km/h on 12.4 x 28 rear tyres.
STANDARD TYRES: Front=6.00 x 16, Rear=13.6x 28, Ground clearance=430 mm.
TURNING RADIUS: With brakes=3.1 m, Without brakes=3.4 m.
OVERALL DIMENSIONS: Length=2,910 mm, Width=1,900 mm, Height to highest point=1,336 mm, Tread=Front=1,280 to 1,880 mm, Rear=1,300 to 1,900 mm.
WEIGHT: (As sold without ballast)=1,800 kg.
BELT PULLEY: Diameter=250 mm, Width=150 mm, Speeds=1,352 r/min, at 2,600 engine r/min, or 17.69 m/sec.
PTO: Standard pto speeds=540 r/min, Engine speed at standard pto speed 2,160 r/min, Pto power at standard pto speed=30.1 kW, Spline shaft diameter=35 mm, Shaft central between wheels, Rotation clockwise viewed from rear.
HYDRAULICS: Pump capacity=393 m/sec, Max pressure=16.67 MPa, Number of remote outlets=0.
IMPLEMENT ATTACHMENT: 3 point linkage, Category 1 & 2, Max lift at hitch point=1,603 kg.
ROPS CAB OR ROLLBAR: Roll bar.
OPTIONS AVAILABLE: Wheel weights, Remote valves, Belt pulley, Power steering.
FIAT 480 DT
MAX DRAWBAR POWER: 27.9 kW (37.5 hp) at 2,600 engine r/min.
MAX DRAWBAR PULL: 28 kN at 3.2 km/h on 14.9 X 28 tyres when tractor weighted to 3,540 kg.
STANDARD TYRES: Front=8.00 x 20 x 6, Rear=13.6 x 28 x 6, Ground clearance=300 mm.
TURNING RADIUS: With brakes=3.3 m, Without brakes=4.3 m.
OVERALL DIMENSIONS: Length=3,030 mm, Width=1,900 mm.
WEIGHT: (As sold without ballast)=2,144 kg.
NOTE: Other details as for 480.
