its not too wide but definetaly eps will be effected
Can anyone here provide me the user manual for Honda City 2007 please? (PDF)
Fixed the manual mode. It was a faulty clock spring. Got a good Japanese one. All good now
I have the same issue, thanks for the heads up.
Trying to keep it clean....
ماشاءاللہI need a lot of work to bring mine to it's former glory. Vaqas Sb I'll be in touch, have put new tires, got my rims polished, and usual maintenance work done.
Looks in good condition, little attention needed :).
I also recently change shock mounts and stabilizing bar bushes that made a lot of difference to suspension.
Btw what tyre size you got? I got 195 65 15. I want to change them to 185 60 15.
Used to have 195/55/15, got 195/65/15 (recommended) and drive is smoother now. Also got my shock mounts replaced a month ago.
195 65 15 touch rear when you hit bumps with passengers and also the front tyre touch on full turn. They also effect economy..
That's my experience exactly. That's why moved to 185
Hi,
Was driving on Motorway the other day, the car started to vibrate when the speed exceeded 120.
Anyone had a similar experience?
Also can someone please tell me the make and type of spark plugs used?
Kind Regards
Can be a variety of reasons, from spark plugs to quality of fuel, fuel injectors, etc. Faced the issue few years ago and it was the crappy fuel on motorway.
I have an i-dsi. Currently, I have 185/65/14 on it. I want to get 195 or even wider tyres if they are compatible with the car and also want to know how the car runs on 15 inch wheels? I'm planning to get 15 inch OEM wheels that came with steermatic and which tyre will be best to put on those wheels?
Go for 185 65 15. Don't put 195 65 15 they touch the rear on bumps and also front when your turn steering to full.
15 works fine on 1.5 not sure how well they will perform on 1.3.
Have the wheels balanced
how much all this costed?
4200 for rotors and 2300 for pads. DIY so no labor..
hi,
i just bought a Steermatic 2006 a week ago ... first car .... so any advises, Dos & Donts will be really appreciated, especially things related to Petrol saving
Get all fluids replaced if you don't know the history. Get plugs, tappet checked. Drive gently for good average.
