Hi there..! Guys i wanna swap engine in my carby cultus as the efi engine is too expensive to afford... I was thinking to go for Vitz or Margala 1000cc engine.....Plz guide me if u have any experince in that.....
i will suggest G13,G15 or G16.
Vitz engine will serve the purpose...
why you need a swap ? what actually you are looking for.... a CARB engine for Cultus or an EFI engine for Cultus.
An EFI engine at low cost
Can u plz tell me the prices also
will let you know the present prices.
Suzuki K10A / K10B either can be rigged to existing transmission. Bolt on over same mounts. make sure to buy it with the ecu & wiring.
Sir series are different. Mounts can be similar but cannot be same.
mount designs may vary but the mount locations will be same...
Yes mouting location is more or less the same
G series will be easiest to swap but yes K series is new and efficient you should also prefer them.
G13 A or B are expensive and availability is less.G15 and 16 are round about 55kThese prices are quoted from karachi.In Lahore prices will be little higher and availability would be less. Can't say anything about Pindi and peshawar market.
@Hassan1991 G13B engine i guess it comes in swift.. my cozn has swift and trust me he is always crying for patrol consumption If k series can be installed in cultus without any alteration i would recomend that... Coz they are new technology engines with good effi.....But i dont have any idea about the prices of those engines on market....My mechanic suggested not to install k10 engine coz they are designed for light body cars and it wont work in cultus ...he suggested me to get a margalla 1000cc engine ..with ur own gear joint to it...and it will cost u lesser
Whats on ur mind ...wt u suggest me to do ?
Swift came with M series engines, baleno came with G series enginesMechanics know nothing about torque and hp, k10a pumps ~70hp with ~122 nm of torque while cultus G10b pumps ~48 hp with ~77nm of torque so how k10a lacks in this chassis.
K series will not be bolt-on as series is different G series will be bolt-on.K10a should be cheaper.
Ok so if i say margalla 1000cc engine vs K10 which one do u recomend ??
Margalla had g10 i think so.K10 all the way....newer and better.
G10B 60hp @6000rpm with 78nm or torque.
