AOA all PW memberscurrently i'm in a mood of tinting my car according to the following setupfront windshield strip 100%front doors 25%rear doors 50%rear windshield 75%my many frndz r uzin dze mch tints n they havnt been caught so ive planned too to get my car tinted.the point i'm asking is dat concerning da rear windshield, many ppl say dat tinting it frm inside damages the defogger lines...is it true?? and if i do it frm da outside...it wil get ruined by dust and water.need a lil help herethanks in advanceregards, Ali Usman
yes it does damage them at the time of removal. when you remove tints you have to be very gentle and careful.
tints r not allowed....if yes to wht extent..??
Dont know about what others think, But Tinting the rear window 100% blocks the view completely for the car behind you... Increasing chances for him to hit you in an event of heavy braking ....
Get the rear screen tinited from outside no problem's, except if the car stays under direct sunlight for hour on end everyday that damages them.
thanks alot for ur suggestions evry1!! i appreciate..!!
if u want to get in trouble get ur car glass tinted
slight change of plans for the rear screen...got it tinted 50% instead of 75%. rear indicator and reverse also tinted 50%.
Car lookinf hot. Rear tinting from inside will damage the deforger lines. This is for sure.
thanks..!!! and rear screen is tinted from outside..!!
mashallah your car is looking goodtint from outside ,,,,,, strange ever heard b4
tint from outside ?
wash it once and itll come apart
thanks alot..!! i have tinted the rear screen from outside because i didnt want to mess up the defogger lines...and i know and have seen many ppl tinting their rear screens from outside
only the rear screen and front screen strip are from outsidethe car has been washed twice and i have also run the wipers to check if the tint peels off but everything is fine without any issues..!!
The tint wont go off by washing the car. As a matter of fact, it won't go off even when you want it to. Just try to remove it after some weeks or a couple of months, when the color would get fade. But no problem. It'll require some harsh treatment with a blade and everything would be fine.
my car mostly stays at home, so i dont think that it will fade in a matter of weeks or a few months...i'm also about to get tint permit in some time in order to relieve myself from the tension given by police
Well since you got tinted the rear glass..Might as well remove the back view mirror as well.Coz u wont be needing it anymore.
Its all depends on paper being used for Tints, If you go with good 3M paper it wont get off and if you want to get rid of it , It will just peel out in one peice. Not to mention it will not block the rear view as the 3M paper changes shades as per sunnlight, so in dark it will actually be lighter..
it's not that much dark...it's just 50%
well honestly I don't see the point of tinting the rear screen..Doesn't the blinder is enough??
