Couple of questions
Any pick and pull junkyards in Karachi/ abandoned car places I can go to pick out a couple parts for my cultus? (need some insignificant things, auto choke, or the whole carb, pcv. pipe and spring clip, radiator hose spring clip, fuel lid spring)
without compromising my safety that is. or dealing with some other lunatic. I'd be down to hit the Aziz bhatiii one, but not alone, if one of you'd like to go I'd be ecstatic.
I know there's on near Aziz bhatti park but idk how accessible it is.
I only ask because I cannot find these items.
Next oil change is coming up; After a decade of using 20w50 oil without tstat and auto fan. I switched to 10-40 a while back and got my cooling system to factory spec (disregard the heater core for now, I cannot pull off the pipe off the second inlet, tried a lot) tstat and auto fan. Noticed a huge change in how the car sounds and accelerates, now that the time has come for a second oil change, I'm not sure if I should opt for 10w30, 5w30 or stick with 10w40. Please guide. Currently using zic.
Rpms
Stated rpm issue earlier, another thing I noticed. Car idles at 800, interior very light rattling. If I ever so lightly push, (not even a push, like a breathing on the pedal, that's how light im talking) my foot on the accelerator, like so light, it feels like the play in the accelerator but the rattling dissapears and the rpm needle does not move.(or will just a little if I push a little harder than usual) So my guess idle rpm needs a very slight idle rpm adjustment to Make idle smooth. Or is there an issue with my accelerator cable?
