the immobiliser in liana will allow the starter to crank as its a fully analog circuit leading from key to starter, however the ECU is intercepted with immobiliser and it will not fire the injectors, coils or even allow the fuel pump to run if the immobiliser is active.
if your car is having random start issues with blinking check light then its time to have the key and immobiliser unit tested as they are failing.
