hi guys, I have a suzuki liana 1.4 ddis , a few months ago broke the timing belt , I took her to the service, the driver changed and said that something is not broken anything other. After 4-5 thousand kilometers, I came spiral board and chek engine. Hold your fire engine, not raise speeds above 3200 rpm. I went to the service and were repaired injectors. After this 3-cylinder engine work.It was mounted injector not believing that he is out of work, but it was good. After installing all the place, the engine does not want to start. These faults occur after a diagnosis: P1207 , P1163, P0102, P0266,P0264. Errors have been removed, but one remains : P1207. The engine just does not start. A ramp was measured pressure and is very small, plays between 6-28 bar. By the time must be at least 280 bar . What is itPlease help me !!! Thank you !!
