Yup recently installed.
Temperature and fuel average displaying fine? how much you paid for this?
Yes, I have with the help of @arslanjanjua1
Can you help with the connection for temperature sensor?
If your'e from lahore then please contact brother @arslanjanjua1 or if your'e from khi then i can recommend an electrician who can do the wiring/installation of temp sensor.
Which is better zic 5w 40 or Mobil 2000 10w 40?Price almost same zic 3250 and Mobil 3050Next is liqui moly 10w 40 for 3600!!So best option??
Come on guys reply do u think semi synthetic Mobil 2000 10w-40 will be better than fully synthetic Zic X9 5w-40?I know mobil is a much famous brand but does it bypass zic fully synthetic?
Fully synthetic is better than semi synthetic.
And when you compare Zic and Mobil.
Mobil is better than Zic. Try to use fully synthetic from Mobil
Bhai mobil fully synthetic is Rs 6200 for 5w-40But the guy in MAL (mobil distributor) saying that tgeir semi synthetic 10w-40 is much better than zic fully synthetic 5w-40But i am confused because of full synthetic and semi synthetic difference!! How they can be equal even? Secondly Lubricant Mart a big distributor in Karachi is also negating MAL guy statement saying that if even i have to buy 10w-40 than go for Liqui Moly 10w-40 for Rs 3600
It's up to you.
Either go for LM 10W40 or Zic 5w40
If price is not an issue then I would recommend LM 5W40
Why lm 10w 40 I think it will also be semi synthetic!!!Mobil is cheaper 3050rs whereas lm is 3600
Decision is up to you. If price is issue then use Zic 5w40
Anyone yet tried Liqui Moly Molygen 5w30 or 5w40 in Swift? I have heard that its something outstanding??
I am using 5w40 Hi Tech Synthoil (Fully Synthetic) and fully satisfied
I am also using zic 5w 40 and fully satisfied but i have heard wonders about Molygen that after pouring and driving for only 2km i will see a great difference in drive
I've got a Swift 2011 model. I am facing RPM problem. While driving the RPM starts getting low and suddenly engine light pops up. When i went to the concerned person firstly he tuned the car but same thing started to happen after a week. When i gave him the car back he said there is an Error of O2 sensor which isn't easily available and if by luck it's available then it's used. One of the mechanic recommended me to have a throttle body but later on he also tuned the car which worked for 2 days. Please guide me what should be done in this regard? Car is continuously dropping the RPM making the Car vibrate and off.
r u sure ZIC A+ or Zic xq oil life is around 20000km ? i was thinking must be around 8000 to 10000.
Yes what i came to know. And life of all fully synthetic oil is around this but mostly people change much earlier
5w40 Hi Tech already have these additives because it's premium oil.
