Option 1 is better. I have done many times and quite satisfied as Base will be original.I have good experience with following:
He repairs in very professional way.
that's why i'm saying, perhaps clutch plates are starting to worn out...because 3100rpm at 110km/h for a manual Swift is high.
i've tried it many a times on M2, it reaches 3100 when the car crosses 120 speed
Is it better to install a Qabli suspension in Suzuki Swift 2011 ? I also heard installing a Qabli might cause a problem of sensor matching which may cause a hard steering
Okay tell me how much often it costs you ?
Does anyone have experience with this master cylinder? https://www.pakwheels.com/accessories-spare-parts/ultima-master-brake-cylinder-for-suzuki-swift-2009-2020-ufm-8913-4439494
There were multiple dents and paint work in my car inclusive of footboard so individually I have not paid, I have always paid lump sum but usually ranges between 3,000 to 3,500 per piece
Assalam o alikumIs any one wants to give off or sale bottom boot tray of swift?
i am also looking for this meter but unable to find it anywhere in pakistan, anyone got any leads please share detail
Assalam O Alikum i have suzuki swift 2016 manual engine makes a hiss sound after the engine is switched off idk what is this sound and why the car is making this sound can you help me with this i will be very great full.TIA
It seems normal. Usually it happens when AC was switched ON while engine was running
Chronic issue of speedometer malfunctioning has come.Where in Karachi is the right place to fix it ?
Without Ac also same problem sound is from under the air clean box I have the video as well if you want I can show you
Sorry for asking so late, but where did you buy this filter from? The Indonesian one?
As I remember while visiting Lahore I bought it from a oil change shop but even i felt that he didn’t have another same one.In Karachi will try to find on my next oil change
The correct sized Oil filter for M13A is Guard GDO-196. Shopkeepers usually try to push the Mehran Filter, which is much smaller.
Stay away from guard or smaller size filter. Only use right OEM size filter available in Suzuki Genuine, Leppone, JS
Assalam O Alikum Which Coolant to use in suzuki swift? When I bought this car ismay pink wala tha can anyone suggest I'll be doing the radiator flush myself.
Just buy zic coolant
Now from dealership you can get Suzuki coolant but that's in blue color.
