Asalam o Alaikum. Hope you guys are fine. And may Allah bless your life and relationships and things and health wealth children etc.
I'm back from Umrah Alhamdulillah
Kiya garmi hei idher. Itni wahan nahi thi.
it has been 2 months but the water level in my battery havent going down more than 2 cm, its not even noticable.Daily load shedding is for 4 hours, should i replace all electrolytic in it now as this one is a little old now?
New batteries don't decrease water level till 4-6 months depending upon the load and good ups or inverter. And its AGS batteries that you have. Dont worry. Correct me if u learn something new. Whatever i say is from Abid.
Looking for a wholesale Dry Battery supplier in Lahore or Islamabad.
Contact Waqar at 0322 4001268
... same here ....
i have Phonex x230 ... with homage solar inverter ... 900 watts ... battery level not going low as 5 cm approx .. with daily load shedding ..fo 8-10 hours ... 2.5 hours each ..
How old is your battery ?! Atif
purchase in may 2017 ...!!
Quite new. I purchased 27 march 2017. And told user xxx. Coz he got two AGS 200 batts. Lets see whose performs better. Count yourself in. If alive, you will get feedback from my side. May Allah put barkat in our things.
Hello all. I'm looking to purchase a 10-15kva generator in Karachi. Specifically looking at locally made (kabli/desi) generators. Any suggestions for reliable mechanics or companies that can make them here? Thanks!
If i want to replace battery acid, should the battery be fully charged or discharged for this process?
It should be fully charged
Thank you.
Today i checked my battery, the plates are turning grey, they were white before and there is some black matterial particles stuck inside battery. Its 5monts old.
Watter level is just 3cm down i will add today
Asalam o alekum From last 3 to 4 days i have read many post of this thread. i think i should start implementing it ..... @kick_in bro can you show your setup bcz i live in karachi and wants to see before going for solar. Last year we bought gen of 3.5kva Jascoo and in start for about 1 year it serves well, but afterwards its start becoming pain .... bcz of its maintenance issues, engine Overhaul etc Total cost from last year including all is 160k.... Now i'm thinking to move to Solar pannel. BUt issue is this that my DAD is not in favour of solar so i need your guidance in following: I'm planning to invest less in this, so once my dad starts agreeing then i'll increase the solar plates. I'm thinking to go for around 1000watt solar pannel setup. so can you guys guide me to go for which pannel 1. Mono2. Poly 3. Thin filmand yes about the Solar charge controller and batteries too for backup of 3 to 4 hours in night. My mood is to first run Fridge ( 160watt 1.29 amp ) and 3 fans and 4 led. Kindly suggest me the best you know JAZAKALLAH in advance
This is NOT AGS. RIGHT? I remember you have 2 AGS batteries 200. Which one is this ? My AGS is going fine like new. Infact my relatives AGS 175 is 15 months old and gives as good backup as new. On Abid's UPS.
that is excide 165, and i dont have AGS bro.apparently the water level was looking just 2-3 cm low but it took about a quarter litter of water to fill cells.I should have filled it before.
Saqibyasin go for
6 x 320w Panel1 x 3kv inverter (mppt preferred else pwm)2 x 200ah battery (gel or dry or flooded)
For more details you can email to contact@solarsystem.com.pk and get free estimate.
Oh i confused you with gull-s-777 brother. And your battery is 5 months old and already decreased water level? That quarter liter of water was needed.
How much is loadshedding in your area. And your load? Using inverter or ups ?
bro its with homeage ups and load is 300-400 watts on it.load shedding is for 1 hour and 3-4 times in 24 hours.
