Ok. Will check at the said place in next visit.
What about in Lahore for Power Side Mirrors??
Bilal Ganj
estimated rate from Bilal Ganj for Power Side Mirrors?
powered 5k.
Roomy, fast and comfy car. Only problem I had was paint - when they wrap them up and ship them over moisture collects between the paint and leaves bad marks. But I fixed it with a heat gun. A great car for not too much money!
Thanks
Bhai i need your help, my car in the morning time give smoke and after 30 sec it is gone. Also it reduce little bit oil like on 1500 KM only half a quarter oil.Can you help me that changing the valve seal will eliminate the smoke.
How much it cost a new one .
There are no new ones. They're used.
Go for a compressiin test first. Then let us know the readings of all 4 cylinders.
Valve seals change krwani paren gi.
Any place in Peshawar to perform compression test ???
How much will be the cost of changing the valve seals ??
Better place in Peshawar ???
A year ago me NY change karwai thee without removing the cylinder head.900 ki seals mili thee 3k labour.dont know about Peshawar.
@fawadskj I can recommend a mechanic ALAM ustaad in Peshawar charsadda road, he will take care of your needs. i used to go to peshawar from isb to get car tuned, mechanical work if any and tasty tikkas
very clean internals of your engine.
Have you install any Door Open Indicator in Baleno ???
I think it's easy (if the indicator is already there in the Speedo).
Can you share the pics of the speedometer with open door indicator ??
