yes only aluminium Chinese radiators are available, but do not buy the one with dual cooling/lines as it will make your life difficult in winters for using heater. car wont warm up for good 20 to 30 minutes drive and there will be no heat to wipe the fog on front screen.
Thank you for the replies. So here's the update bought a Thai made radiator for 6500 and then came to know fan wasn't kicking in. So fan motor had to be changed and that was for 1800 with labour. Comparison of new and old radiators.
Which fan motor installed? Usually they put in alto's
That i dont exactly know he said its balenos own fan motor.
Can anyone know how to check Baleno CL level..
since the day i have changed the radiator i have to top up it with 250ml water on daily basis. I have changed the radiator cap twice but problem is still there. Before getting the new radiator i used to top up the reservoir bottle with 250ml water after a day or so. Can anybody suggest whats the problem as water level in reservoir bottle isnt decreasing now as if radiator isnt getting the water from there. Anyone pls. Thanks.
@capsat @margallar
Did u check the housing pipe connecting radiator with water body. There might be small leakage in that pipe. I recently change that pipe as it was leak due to rust.
CL level mean?
there might be a leak, bypass the heater core temporarily (uski coolant supply bandd), and inspect all the coolant pipes for leakage.
also look around the water body, esp when engine is hot.
If no leaks, the head gasket is gone
Alright I will check that too, however I noticed a few drops leaking from the expansion bottle pipe where it connects to the radiator near the radiator cap and engine was running at its optimum temperature. Thanks.
I repair my Baleno watch by myself. I check the resistance of the resistor which are mentioned no as 101, whose resistance is 100 Ohm.
Re-Soldering the resistors, working fine.
Same here. I also did same. Just got out the watch and resold all components. Now it's working fine. Previously it got dim after turning on with passage of time.
Bhai meri clock sahi krne me koi madad krne ko tayar hai i am from Karachi
Kindly share the pics of your clock. 1st Remove it and then open the two screw and take a snap i will help you and will show you how to start working again.
https://youtu.be/gC9G-beWt-U click on this link and watch the video, Same procedure is applied on baleno to check and replace gear oil.
please recommend the best fuel pump available in market for baleno...
Denso
price??
I recently changed fuel pump of my Baleno. Already discussed it in detail in my ex-posts of March/April. Chinese, malaysian, Japanese all are available brand new. I installed japanese. See attached picture of my experience earlier this year.
plz share post number or else
