cylinder block was the most dirty part ,,,,,,, first use kerosene ,,,,, then pressure washed it ,,,,, and then use engine degreaser ,,,, and finally pressure washed it for the last time,,,,,,oil galleries must be properly flushed and cleaned from inside ,,,,,, before final assembling i will once again flush all oil galleries with carb cleaner,,,,,, this is the most vital step in block cleaning ,,,,,,also i will paint it with high temp engine enamel ,,,,,,,,,
