Dear pakwheelers,
We've successfully swapped a ke70 in Islamabad at dmotorsports. It had a 1c diesel engine earlier..
The car owner decided to use beams on 2c long ratio tranny and it fitted bolt to bolt...
Since it was the red top third gen beams so we had to customize the intake manifold completely and then cais was installed..
We did 4-1 Headers and then 2.25 downpipe.
Cross member was end based and was upgraded to its own manual steering on cross member from body based end system...
Then we shaved the wiring from bay and give it a shaved bay concept, so no wire is visible in the bay.
Secondly we've installed electronic power steering for quick maneuvers, so that we can handle it easily and comfortably...
Fuel tank housing was customized and then whole tank was painted and installed the new fuel line and walbro fuel pump..
We also painted the dashboard since it had some parts of blue colour so we painted it brown, so whole dashboard looks nice... Rpm meter of ke70 is also purchased...
Currently posting the swap pictures and stepwise photos.. Later on will post the final photos of polished bay etc...
