Yes its normal broHow much did you get it for
Thank you sir.
It's a 1.3 G push start, climate control, Factory fitted sports spoiler, Model 2008 Import 2010, Gun Metallic Grey.
I had to get the suspension redone. Over all a very nice ride Masha Allah
can you please tell belta 1000cc fuel consumption ? as i am looking to buy belta
Don't get 1000 cc as it will be underpower and will require more power hence more fuel consumption. Go for 1.3
ok but atleast can you talk me about 1.0 cc or 1.3 cc belta fuel avg?
Sure. My 1.3 Belta gives 17km/l on long route and 12km/l in city.
with luggage in trunk and 4 passengers on board?
good
can you share your belta pics where you live i in live Karachi
will these plugs fit belta 1.3 2szfe cvt. got rhese plugs from outside pakistan. i had to return previously imported plugs as they were not long thread.
the above plugs are long thread.
these are the perfect plugs where you got them from and how much couldnt find them here
sourced them from Canada. cost was 10$ cA each. they also had superior plugs than these ones for 15$ each with 200000km life but i opted for these ones. also imported stablizer links which have greasing option on them and denso cabin air filter. it was worth to get these items from there as they are far better in quality.
I have purchased belta recently its fuel is very bad it only giving 9 to 11 without ac what to do whether in install cng in it or not
it is not a fuel efficient car.
tintin1 you opinion required i have changed my engine assembly 2sz-fe 10 days ago i am facing an issue during ride when i pushed break during ride when i push break to slow down my car its okay but when i press race paddle again for few seconds car dint picked up and then after starts acceleration .(in urdu race dabanay par after break car bethi bethi si feel hoti hay .car ki speed nahi berhti or thora or pedal debanay par aik dum say race berha shoro hojati hay .
I have Belta model 2011 and need to replace engines Assembly. Its original engine is 2ZNFE. Please recommend me which engine assembly shall I replace with. Can I install 2SNFE instead of 2NZFECorola XLI use the same 2NZFE, can I fix that and is model year matter while replacing engine?
In my "OPINION" If i get it right " brake k baad jb ap gari uthatay ho to 1 ya 2 seconds k lye gari response nai deti jese k gari band ho gai ho aur us k baad khud e 1 jhatkay k sath uthti ha?" my car did the same and the problem was something about the jets of carburetor as that was car with carb engine. For EFI i assume there must be a problem with fuel injectors as these are used in place of carburetor. First clean and adjust the spark plugs and point. Get the spark cables checked. Clean the air and fuel filters. If problem persist, then check EFI.
