Perfectly fine, a friend is using it in 70k+ driven grande. Use mobil 1 5w30 instead. It's new in market. I have stayed on higher viscosities from day one, i'm a bit hesitant on using it. If you have less mileage on odo than go for that. My car is already at 81k kms.
Fyi: there is a heck lot of difference between a 2zrfe and 2zrfxe engine.
Occasionally at the start there is a sound like KHURRRRR and doesn’t last longer than the speedometer initial full clock turn. It seems as if something is loose in engine
It is just at the engine start.
Not sure why you comparing engines because I didn’t.
Gurrrr or tick tick type of sound? If that's the case than its normal functioning when you're using taglon 5w50. Whenever this sound comes low engine oil pressure light will show up on meter cluster. I was tired of this sound, and decided to go towards a better oil. It was barely audible or suppressed while using these two oils.LM 5w40 synthoil hightech fully syntheticMobil 1 5w50 FSx2 fully synthetic
Try Collinite 476S or 845. Both are very durable and long lasting, Collinite claims that 476S can last up to 10 months. I have recently applied the 476S and tested its water beading, fully satisfied. Bought from Autohub.pk
Regards.
I'm not sure why you're linking your prius with IMC manual, that's a cbu or japan import. Well the engine oil that comes in corolla is recommended by the company. Thought you were linking prius engine with a rolla engine coz both engines belong to same 2zr family.
I have used collinite 845 a lot. Lasts 3 months easily. My running is 7-10k kms in 3 months. Now i'm using tonyin, lets see how much it will last. Costed me 800rs which is cheap. Heard a lot about it.
Yeah all new Grandes have 2gb unit
Wow, that's one cheap wax. I remember Autophile once recommended me that as one of the options, though I went for 476.
Btw, Sehri time is about end
Sir g they have no logical reason to decline request and of course they will try to delay but u need to stick to the demand. We didn't pay 3m unit to use YouTube at 240p lol
I tried that on my wagonR but maza nhn aya..went back to 476s ..my 845 is finished so 476s is the best so far to me
Glad to know it is better. You guys once gave me second thoughts after I purchased the 476S and then I thought 845 was better. Lol
I'll probably be a grandpa when I'll finish the 476s box
476s is harder to usr than 845. Its equally good provided surface is properly prepped
Btw, may I ask what shampoo do you use for your car?
Karcher is a blessing sir, it saves so much time. A must-have item.
I use carpro reset..
Bros, I just bought an FL Altis Grande.I have been driving the civic 1.5T for the past 2 years. First thing I noticed on the Grande was the lack of grip.Thinking about changing tires to 215 55 16 to enhance road grip.Yet my research shows that the Grade suspension has been tuned slightly.Anybody here has experience with changing tires from 205 to 215?Does it have any adverse effect on the suspension in long/short term?How else to solve road grip issue.Any advice would be appreciated.
Regards
