I recently bled my brake lines turns out the fluid I used was not a genuine product.Thus,corrupting the whole brake system.The first time I sensed it when all of a sudden my front driver side brakes got jammed up in addition to the brake pedal becoming rock stiff.I wasnāt able to move the car.The only option I had was to open the brake nipple on that tyre and let the pressure go down.As a result my brakes became free consequently with the brake pedal going to the floor.It was a hassle to take the car to the mechanic.After I did I came to know the brake cylinder has expired.Changed the brake cylinder(Rs 4000) as well as the clutch cylinder(Rs 2500) as both were inoperable.After the mechanic installed the new brake cylinder and trying to let air escape out of the system,all wheels were doing fine except the passenger front.Thereās no pressure building up in that very line.We tried opening the rubber clamp connecting the brake calliper to the brake line as our assumption was that the rubber pipe was the suspect.It was all good.The passenger front brake is not active and the car is out of balance when brakes are applied.
Any insights,on what the problem could be,would be appreciated.
Regards.
