assuming the oil grade is the same which you have been using before,
Yes, same oil grade. (BTW the oil i am using is fully synthetic not semi, i rechecked the bottle. its zic x7 10w40)
the spark plugs are genuine new and the ATF oil is as per actual requirement .
Spark plugs DENSO K16R-U11 and ATF type 4.
Was in the same packing.
Hi-Octane may result a quick throttle response but fuel avg improvement is highly unlikely to happen
The car is running smooth. sometimes i just feel like the only first gear is taking for RPM to shift next gear. I got scanned today and Alhumdulillah RPM and other stuff all was in OK condition.
Is sey pheley wale b spark plugs same the and un k sath engine oil engine karwaa tha and i was getting approx 9km/l with AC. This time spark plugs change karwae tunning etc, throttle body was clean. and it started dropping the average. BtW jab yeh kam karwaya tha that time gari me petrol new pump station se dala hua tha. was not the one i always use pump station.
is sab k bad i refil tank 2 times but i am slightly improving the average. it was even worse then 4km/l. as i normally refil tank when the needle touches the quarter.
So two things, spark plugs or that new petrol station fuel. ya phir injectors clean karwa do, didnt get change the injectors my bad.
The posted additive will make no difference.
IF its not harmful can i give a try? as according to ustaad ji, it works according to his experience. now wallah alam.
