Toyota prius abs unit keeps on failingWhat are the reasons?Is there any solution ?
Sadly replacement is the only solution and you will have to buy a used one..
Yes, but do you know how to make it last longer?Is there anything i am doing wrong that makes it go bad. Or how to take care of it?
Brother it’s an electrical components so there’s no maintenance as such. All you can do is keep your brake fluid at proper level and maybe get the oil in the lines properly bleeded and remove any air then add new oil. Other than that in most cases people complain it fails for no particular reason and it is a known fault in this generation.
Thanks brother,I changed it and it lasted for a year, then i changed it again it lasted for 6 months only. This is the 3rd time the same fault has arisen.
I really love this car, drive, features, comfort. Fuel economy. Everything is perfect
Yeah me too I own the same car and it’s awesome. I am planning of keeping it for ever . I haven’t faced any problems like that yet. The only problem I’ve ever had with it is inverter coolant pump which has failed 2 times in the last year and this time I replaced it with the newer model one. I also had A/C issues on which I’ve spent well over 50k so every component of A/C is now changed. The ABS pump is an issue but I think it lasts a lot more than that of course. Get the car checked from some educated electrician I would say.BTW where are you residing??
I live in karachi, near malir cantt
Hard to find an educated mechanic
Hi I am residing in Lahore if you know any mechanic for Prius please tell
Finally I found the main reason of prius abs failure,it is with break fluidDo not use guard or other local brake fluid, Just Use toyota dot3 and I’ll assure you that Prius abs will not not fail in Future
