Didnt quite get it
Brother I just installed Tyre in stock size from discount tyres in Islamabad (dunlop sp1 touring) and I'm satisfied
How much did you got those for???
I think 185/65/15 is good option. I found aqua stock dunlop eco tyres in LHR and feel my ride more stiffer as compared with 185/65/15. Next time I will go for 185/65/15 as it gives more ground clearance, more comfort and good breaking. How ever fuel efficiency is drooped from 1 to 1.5 km/L.
Has anyone got his cat con serviced till now in aqua?
Yep
Dear all Kindly recommend good place for engine bay steam wash in lahore prefer near Johar town
How was the impact on milleage after cleaning and how much time did it took?
I got thortal body and cat cleaned together, with oil changeAlso gear oil was changedThere is increase of 3km/l There also is weather impact as now Karachi's climate is bit coolerDue to smoothness and I have now started hard padelling So cannot confirm the overall impact but its better then beforeMy brother in law is mechanic so I left my car with him for the day so cannot confirm actual timing approx. 2 -3 hours
You are lucky than... probably i shall be spending a day for these stuff.... anyways thanks for your valuable response 🏻
HmmmCan provide his address if you are in Karachi Yep think it will be a full day job 12:00 to 6:00 or maybe 7:00Best of luck
I would have ask for it but in lahore. Thanks alot.
Aoa pakwheelers, i want to ask one thing that can we change toyota aqua multimedia language? As by default language is japnese.
cannot be changed except in some LCDs like W62, but that too only the main menu not completely.
Need guidance.With sad, My right side mirror has broken, only glass, what should I do... Bilal ganj Se glass mill Jae GA easily..?
Easily available....
can anyone help me in getting the auction sheet record of this below chasis number NHP10-6251295 till sunday nightthanks
2 options1. http://japanauc.com/search-img.php2. Search on Pakwheels
Pakwheels will charge you 1000 rupees
Mushtaq Bhai this car is registered. Will be there record at pakwheels?I've already checked on japanauc.com but no history
