I am using LED in low beam in Gli and aqua
High and Low beam in imported alto as its a single bulb
And about fog lamps you should do more research or take a look at your car and check if the wiring is present. If it is not then taking power from other electrical components and cutting of wires i never recommend to anyone. I am OEM type of guy so i use only plug and play type item
Even in my GLi i am searching for the indicator stalk like Grande that has a ring on it to turn on and off fog lamps instead of those ugly buttons. For me its either OEM or not at all.
