Masha Allah nice one. is it probox the second car.
W.salam. Both have same meters as far as i know. The 1.5 will be better as 1.3 feels sluggish sometimes. On occasions it downshifts immediately when you floor it but mostly there is a annoying delay. Air intake is a device to increase airflow in your car.
Assalam O Alaikum. I have probox 2006, 1500cc automatic. I have an issue, It's engine is getting hot and when I stop the vehicle for some time, i check its water level in radiator. I find that the water level have gone down. When i fill up the radiator then it goes cool. But sometime the engine again gave red light ( overheating light) Anyone can tell me that why this is happening? What should i do for this? I have bought this car one year earlier and I have driven it 15000 KM up till now. Thanks for help.
od button means over drive button when u exceed 80 km then u can on this button
Does any one know how to remove the old Stereo for probox or could at least let me know where are all the various places the nuts located for removing the stereo dash column.
mry pas toyota succed hy....2006 model rgstrd 2011:::mjhy is k suspention ki boht prblm hy....koi axa wheel balancing or suspention wala btay lahore me
Aoa. Guys. If anyone want insurance it can be arranged at 2.35% through Adamjee Comprehensive with 3rd party. A further discount can be given to pakwheelers too.Inbox me if anyone interested
Kya prize hai probox ki hm ko be leni hai probor
Does any one know where i can get lowering or adjustable suspension for a Toyota Succeed 2004, in order to decrease the ride height? Thank you.
ahahaha
kya koi bta sakta hae k 2nzfe 13oo wali probox main 1500 cc 1NZFE wali engine assembly laga sakte hain?
Yes laga sakta hay
Assalamo AlekumFriends I have about one million rupees and I want to purchase Toyota Probox 1500cc.Please tell me that can we place extra seats at the luggage place of the car at the end for increasing sitting arrangments and if yes then from where we can do it ??
[quote="junaid_juni, post:859, topic:176171, full:true"]Assalamo AlekumFriends I have about one million rupees and I want to purchase Toyota Probox 1500cc.Please tell me that can we place extra seats at the luggage place of the car at the end for increasing sitting arrangments and if yes then from where we can do it ??
The OD button is used for boosting your acceleration by shifting down the gear when you press the button. Its usaualy used when you are driving at 130 . 140 and still want to tqke overtake or boost you engine .. you press it and you will find like the engine is doubling its power... but i think regular drive qith OD button pushed on will harm engine because it seems shifting down the gear and increasing rpm.
When th OD button is on you will find and OD swith on in your speedometer.
130-140 would be a bit fast to switch off OD. 80-100 feels safe imo.
The boost acceleration and double engine power is simply the change in rpms when the OD button shifts to and from the top gear..The OD option is simply an additional gear (final drive) to ur car....usually its the 4th gear that gets active or not..In regular drive the overdrive should be ON as it keeps the car in top gear with min possible rpms and saves you from excessive stress on engine when u r driving at sharae faisal at 60 70 and ur rpms are about 2k because u r in 4th gear instead of 3rd..OD off at 130/140 is like 5k rpms at 3rd gear which u would not want to do to ur normal car.
Thanks, i did it, engine assembly buying is very tricky thing , now and u hardly find some good engine assembly, but 1500 1NFE experience is really good, the pickup is amazing, like a race car, and good fuel average. its fun to drive now
Dear Experts ,
I have recently swapped the Engine 1NZ in my Toyota Probox 2010 , complete engine gear ecu n wiring Swapped (Kabli Engine)after driving few hundred KM engine start consuming engine oil ; like in 1500km the oil level comes to middle plus fuel economy is very bad,10km/l in city without AC & 11 to 12 on highways without AC please help me what to do.
Bhai what is the condition of your air filter?Spark plugs?Which type of oil are you using?Was there previous engineer used with the same type of oil and did that old engine also consumer oil?
