Yes, Get the Airbag connectors reseated to make sure they have proper connections. Our rough roads can sometimes dislocate the connectors.
This is safety critical item. Get it checked from Toyota dealer.
Aslam U Alikum i have Vitz 2008 . recently i notice that when i press throttle very hard then it make smoke. why ??using Zic X7 10w40what is the problem ??
Whats the colour of the smoke white with blue texture? If yes then engine is detoriated and needs to be rebuilded.
AOA Fellows/Experts/Vitz Fans/Owners,
Need a bit of guidance, i need to replace front Z links on my vitz.
Have 2 options
1- 555 Japan 2800 Rs/Pair2- Thai RBI (dont remember brand name exactly) 2600 Rs/Pair
Please guide which one should i opt for?
I have vitz 2013 model impor 17. Please tell me from where i can get genuine break pads and shoe (other then toyota dealership) their prices are bit high. I based in lahore.
Toyota Ravi (Montgomery Road) is 1S Authorized and their prices are around 20% less than 3S dealers prices
Z links buy the thai cheap ones will cost you 1000-1500 pkr they work great but also check the Rack ends and Ends also and dont forget to check the lower arm busher and one thing more Ball stud's:relieved:
Alhumdulillah i have 2013 model, but there is no place inside where I can hang my coat, dress stuffs etc
ok thanks.Thai Z links are 2600 Rs. Chinese are available for 1500 Rs.
aoa. 0w20 or 5w30 by Zic available at metro cash and carry Islamabad.. Which one wi be best for my vitz 2013 ...80k on Odo...currently using patron Toyota 10w30... till now doing well...but in last oil change by mistake 20w50 was used and since then it consumed engine oil 400 to 500 ml in 3000km. Getting Zic oil from metro is a good option...Is Metro cash and carry selling original Zic oil...
use total 9000 API SN 5W-30. much better oil and suited to vitz 1KR-FE.
Use the same oil Toyota 10w30, and please share your number, mine is 0345 855 333 2, I will share my experience, have more than 06 vehicle in my circle with same issue and different solutions.
Uploading...
Hello guysMy car fog lights suddenly stopped working. Trunk light is also not working? Can u pls adv solution.
Acc fuse blown or Lid one which model you had
2010
The fuse panelnis under passenger side cowl find the fuse tray their and find brake or cig labeled fuse replace it and you are good to go again.
