Aoa broz. i own a 2OD 2001 model, i am facing following problem. now days i am working in Kashmir. my car runs perfectly good on plain roads but it loses power on continuous steep slopes, i changed clutch plate, fixed fuel pump after which car improved a bit but still it needs improvement, what else should i check? if i stop the car on steep slopes then it becomes a bit difficult to climb from that point then, if i press accelerator the engine do not responds as it should. To be more precise it do not produce GHANG GHANG sound when accelerator is pressed, if momentum of car is broken by stopping it on steep slopes. tx
