My mechankc poured3.75 litr and dip stick shows the oil at 2nd hole.
ok good enough.
just bear the extra noise for sometime and keep an eye on oil level.
Absolutely sir.
yes its fine its the right amount of oil for 1KR-FE in vitz
One correction its 3.1
Same prob with my 2012 vitz
3.1 L is under filling for Vitz 1KR-FEif properly drained 3.1 L is for quick drain fill
what is your vehicles problem?
I had this issue of oil reduction in 2013 vitz. 80k driven. I was using patron 10w30 Toyota oil for 4year. Last time mechanic used 20w50 and it started consuming oil. Went to Toyota capital I9. They checked and found everything ok. So will visit them again. In general for 3000km I added 1L oil. During fresh oil change Toyota again poured 20w50 although I insisted on 10w30 which I had need using for 4 years.. they just asked me to be patient
Don't worryHow much oil is it consuming. An approximate at 1000 Km..?Answer the above and I will tell you what to do. Also tell us car odometer reading. ..
Mileage of ur car?
Well odo reading 80k. Problem started when accodently 20w50 was used rather than 10w30. And next time I am planning to used 10w30 again. Is there any Toyota oil with a grade of 5w30
Why did u switch to 20w50. Forget the mileage. Stick to a thinner grade like 5w30. Yes toyota has tin pack 5w30 oil available at dealerships.
You also have options like shell hx7. Total quartz 9000. Both are excellent
AOA all,
My Vitz 2008 model 1KR-FE 98K driven has started to consume oil. I am using Liqui Moly Super 10W 40. In 2 years I have driven only 10k almost. Previously the owner was using zic oil of some grade 5w 20 or 30 but I changed it to liqui moly and they recommended 10w 40 because of 88k mileage then. When the zic oil was changed it came out full. After liqui moly 10w 40 the first oil change was done after 5k and almost after a year the oil was 1.25 litre less. This time I have checked my oil after 3k the oil is 700 ml less. What could be the reason.
Get the engine rebuild or repaired to counter the error.
how much it will cost me because my vitz 2007 Engine have the same problem (consumption of Oil) approx if rebuild it .......
Well its against the pakwheels laws to sell or promote without the acknowledgement of the pakwheels administration. So sending you the contact number please contact for details and inspection. 0300-5220091
vitz 1krfe with oil filter change 3.1 litre
its normal for toyota engines to consume 1L oil / 1000 Km driven. its clearly written in your user manual of the car. check it.
oil consumption in all new high compression engines is a design trait and not an issue. just top it up whenever required.
