After using bike for more then 8000km i came up with this following:
1) Use yamaha lube. i dont know why people say its bad one whereas whenever i drain at 2000-2500 i still find that it has the strong viscosity and lubrication.
2) Bike is comfortable.
3) Fuel meter is not stable.
4) Very durable and very cost effective as after 8500 km i first time replace its part and that is air filter.
5) Back tyre has some grip problem advised by mech to replace it with YBG tyre.
6) Kill switch and dipper should be there. though kill switch itna imprtant nahi but dipper should be.
7) Lights are good enough pata nahi kun log payndoon ki tarhan even in city use LED lights or laga bhi layta hay but dont that light should be on road and not in the eyes of the others.
8)Speed i Max touched is 110 km/hr. not more then this.
9) A tip: if you feel heat on your foots due to engine and its continuous then tapped setting might be disturbed thats why engine not working as it should be and getting heated.
10) one of the good bikes i felt. its worth of money you spend.
Regards
