AOA all,
i have Santro GV 2007, from the past few days i am having a serious issue and i am unable to rectify it whether it is any sensor issue or wiring problem or what. The issue is that whenever i start driving the car after some time you can say 10-15 minutes of drive, the car starts jerking as if the rpm is not stable. With a very light paddle press i am able to keep it start else the engine would stop. if i push the paddle too hard it seems that the car is taking too much pressure to keep the engine running. With its own will it turns back to normal and when the temperature is normal it does not happen until the car is stopped for a longer period. i have checked it with various mechanics but unable to fix it because when i reach workshop it turns back to its normal state. Serious guidance required of what should i do about it. Thanks
