Brother how do you Wash condenser ??
Wats the solution. Change it to non sensor Compressor??
I have same ac compressor tripping problem in my 2010 gli.Did you guys find any cost effective and reliable solution to this problem.?Planning to visit mechanic in next weekend.Any suggestions?
Change the entire system with originals. Alterations will cause many other problems
What will be the cost of original system.
Original means new original or kabulli original
New original. I changed the system in 2016 and it costed my around 60.is ur car gli or altis. Altis has a dual sensor compressor as compared to the single sensor in gli and xli
Mine is toyota gli 2010. From where i got original system?
What about Toyota clutch compressor kabuli from 2006 model?Is there any draw back or it is ok to use if i get some clean piece?
That would require alteration. Karwa lo if u want give it a try
One more thingShould i change compressor only or also condenser?
Which variant is it? Gli or altis?
Its gli 1.3 2010 model!
If u alter then compressor only rest the mechanic will tell. If u put genuine then entire system.
Which city are u located?
I am from Lahore.Isn't there any chance i got kabuli original sensor compressor and got it installed without alteration?
I looked for them everywhere. Could not find them. Ur ac trips on and off right?
Yes its tripping. Especially on highway its work but then trip when i press clutch and rpm drops to 1000 its starts again.First i tried servicing ac system lets see.
Will try to find out from bilal ganj lahore
Can u please tell me the model of ur compressor? Sometimes a control valve is faulty.
Don't know the. Model of compressor.By the way is control valve is repairable or replaceable if it is faulty.
