Looking to buy aqua, what should i look for in the car like abs, battery, any other parts or things. how much would 2012 S model cost with mileage above 140,000?
you can get the HV battery checked by getting the car scanned and you can also get an estimated battery health percentage.For ABS accumulator leak while in the car notice for hissing sounds coming from the brake pedal. the sounds usually comes when your the brake pedal is pressed while the car is stopped. The ABS actuator should not turn on very frequently (motor which makes a buzzing noise while its on)just make sure the car was not involved in a major accident and is not botched together 2012 model range between 23-26 lacs depending upon condition grade and color
