Dear Members,
I bought Switch DLX 2013 with Low mileage (74k), Car is in very good position. Got inspected before purchasing.
My question is that the previous owner was using water + coolant mix and radiator very slightly rusting water. Radiator was removed and cleaned/washed by mechanic and now water in clean in the radiator. The mechanic advised me not to put the coolant immediately after cleansing the radiator as the hidden rust will mix into and advised me to drive for few weeks with Water so that any hidden rust will mix into water and then remove the water and put the coolant inside.
My question is;
What is best coolant for 2013 swift ?
Also please share your opinion/experience about the Mechanic advise, is that right ??
Thanks
