Bro I have changed engine almost a month ago. I am using Honda 10w30.
@ksadBro which things included with engine assembly???
Is there any difference in CCs in L13 and L15 or is it just a difference of numbers?
L13 is 1300cc and L15 is 1500cc
I am thinking of swapping my idsi 2004 1.3 m/t with 1.5 one. Do you think its worth it as it is nearly a 15 years old car.
L15 has good power then L13 and also is fuel efficient if done properly.
Salaam,
I am going to change My Honda City 2008 vario assembly.I wanna know, which Oil I have to use what will be Oil change cycle ????
I heard that, for first 500 KM we will use 20X50 and after it, we can use 20X50 or 10X40 or 5X30 ????
For the first oil change, I have heard the same and that is what I did too.For the preceding oil changes shift to fully synthetic oil if your engine does not give any smoke or oil reduction issues. 5w-30 is a good choice for Winters. Even 5w-40 will do.
junkyard people usually give a weeks warrantypoint of pouring such a thick oil ?all engine noises and oil consumption issues would be concealed by the thick oil ?buy 10w-30 instead
There's no need for 20w50. You can use any good 10w30 oil. Plus I never take any risk. Whenever buying kabli engines we pour normal cheap oil and flush it after some hours.. We don't even do 500km's.
do you have the contact number and name of Mechanic ?
I need to change engine and manual transmission as the gear was making grinding sound a year back got it repaired but as of now making that grinding sound again, so will be replacing both engine and gear, need a reliable and experience mechanic.mechanic from the same area mithu khan ka ahata would be preferable.. Thank you
This car came with a L12A2 1240cc engine, I have a Honda City idsi in which I've swapped a L13A1 1340cc engine which has 98hp. It's pick up is very impressive and both of these engines have the same price of 32000 rupees
1.5 idsi or 1.5 vtec?
