My reborn give me hummm noise when i accelerate. Its like airplane is on runway. But it gets low on when on speed.
I often used to hear that sound in mehran taxi too.
Is your engine/head been repaired?
wheel bearings gone - most probably.
Not sure about that. I recently purchased it
Noise gets munimized when the car is above 30 40
If the noise is persistent whenever you hit the throttle then It's probably an engine issue but if the noice is present even if you are not accelarating, like your speed is 30 constant and the noise is still there then it's probably the wheel bearing issue
Noise only comes when i accelerate.Noise gets slow too when i slow the car.
But on speed like 50 to 60 the noise disapears (hardly noticed). Basicly noise change its pitch a cording to acceleration.
Whooooooooo
When i accelerate noise starts and when release the acxeleration the noise is like aeroplane is landing
Where do you feel the noise is coming from? From the sides, back or the front?You should get the wheel bearings checked btw.
Getting same noise in neutral while pushing accelerator ?
power steering issue in my opinion.
Nope
From the middle
Only get the noise when moving the car in low speed.
Wheel bearing issue, usually happened after rainy season recently faced this issue in my baleno
The sound is little bit related to formula one racing
Get the wheel bearings checked, not a big issue. It happens
Seems like Bearing issue better get all 4 wheels checked after that get full service and get oiled it will prevent from rusting and lubricate parts so you won't get noises.
Formula 1 Racing 🤣
