Salam to all members here.
I know this is the wrong category to post my query because this is for Mira and i have Cuore but since i have an efi engine so i thought some of you guys can better guide me.
i am facing an issue in my car drive let suppose if a press pedal it takes 0.5 or 1 second to respond and RPM is also not stable. after pressing pedal car takes a little lag to respond back and pick is also average.
Things done so far to get this resolved..
1. Fuel injectors cleaning
2. Throttle body service
3. Fuel pump change
4. Ignition coil change
5. Plugs change
6.Plug wires change
7. Distributor cleaning
8. Map sensor change
9.Proper tuning
10. compression test
11. complete wiring test through meter
All of the above things are done from some of the famous mechanics in islamabad/rawalpindi but still the problem is there. What i truly believe now there is some sensor that is faulty and mechanics are not able to find that manually. Problem is as the car converted to EFI lately so the grip that use to connect car computer to scanner no electrician is able to find that so far. I have been given time after eid by Burraq autos that may able to connect my car computer to scanner. I am looking forward to some positive replies from all of you guys
