Salam. Welcome to the forums. Well the original bulb types of Land cruiser Amazon is 9006 low beam, 9005 High beam and 9006 fog lights. This sehgal motor led bulb is the worst, its the same known as C6 in the market. These bulbs can never produce a proper beam pattern and brightness due to low in quality and most importantly because of the big COB LED chip. This led bulb is H11 by they way, they have sent the wrong ones. If you are really thinking for a proper upgrade, then look for High quality LEDs like BI LED, Philips etc. Expensive but totally worth it. If your budget is low, then look for branded halogen bulbs like Narva, Bosch etc. Good luck
