@darthvader and @Spano
Q: Which shampoo do you recommend to be used with a form lance?
A: Shampoo exclusive to Foam Lances are supposed to be tacky and stay on the surface of the car a little longer eg 6-8 minutes and then rinsed (or like a pre wash). However, I personally prefer using a wash mitt after 4 minutes of spray through foaming lance (in summers). My personal favourites are Autofinesse Shampoo, Chemical Guys Honeydew and even Meguiars Hyperwash.
Q: Difference between APC and a shampoo?
A: Shampoo and APC are different chemical compositions altogether. In short, Shampoo is for exterior surface only with suds. APC, as the name implies is multipurpose depending upon purpose. My personal favourites are Chemical Guys Nonesense, Autofinesse Verso. Keep in mind APC could be used on virtually any surface depending upon the dilution ratio.
Q: Which glass cleaner?
A: Stoner and Gyeon are my personal picks. But other brands are not lacking in any way.
Q: Also, can't shampoo be used as glass cleaner?
A: On the outside; Yes but it will leave streaks. My point for the glass cleaner was for use on the inside specially the windscreen.
Q: Is the Nanoskin Majestic I already have good enough or do I need something else?
A: Use whatever you have at the moment. Don’t go on a shopping spree out of exuberance as there are many options out there. However, next time go for a paint sealant which IMHO is longer lasting protection than waxes.
Q: I got the Maguiars Hot Wheels rim and tyre cleaner, and found it to be quite useless to be honest. Any better alternative?
A: Don’t expect wonders from a product that is not formulated for another purpose. For cleaning tyres and rims your best bet is an APC with strong dilution or a degreaser (in case your wheels get a filthy beating).
Q: Which interior cleaner?
A: No need of a cleaner. For that, APC is good enough. However, for interior dressing, there is a plethora of choices.
I’ve typed on an iPhone and it was a pain in the B. So I tried to be crisp. I could discuss more products. Hope it helps.
