I have a Nissan Dayz 2020, problem is when stationary the car AC cooling stops working, but its very chill when moving. Took it to mechanic and they've checked fan, radiator and condenser, all is good. Gas level is also ok, however mechanic reported pressure in system is high.
Car mileage is also impacted because of this. I suspect radiator running hot when stationary or slow but there is no temperature guage in the car or any temp warning showing up. Water coolant level is also ok and I don't need to topup..
Can any one advise on this or recommend good mechanic near DHA Karachi.
Had a friend with a older 2014 model, with same problem, he eventually sold his as couldn't figure out the solution despite replacing several things.
