Spareparts are easily available from Rawalpindi. The car ride, handling, acceleration is great. One may find the suspension a little bit hard which compensates for the handling. The car will give a tough time in summer, around two months. The car has a battery performance limiting safety feature due to which the battery’s performance is limited above 40 degrees, the car gives an average of 12-14 kmpl (still worth it for the performance). It uses a complex AC system which trips in temps around 45 degrees due to over pressure of the gas, you have to pressure blast the condenser with water everyday in order for it to keep working properly. Note Nismo has very high complain of the AC issue whereas the normal X is good with some issue. This is the only drawback to the car, it gives some tough time in summer. Other than that, car is surprisingly vast from inside, gives excellent driving pleasure, better than Aqua in terms of drive. Before any netizen tries to question my credibility, we have around 8 Nissan Notes in our friend group of every variant except Nismo S. We all bought the car for performance, the buyers of Nismo were very disappointed in summers and one even sold his car due to the AC issue, the rest are fine with it….You can drive mine if you want to check it out yourself.
