Hi,
Please help answer some questions anyone who has a solar setup in Lahore, possibly DHA. I am a newbie seriously interested in getting Solar since my lesco bills are north of 80,000 a month on lesco load i have one meter.
I want to set up a net metered (on grid) Solar Setup in DHA ( open lesco transformers, not underground).
So i want to run the following on Solar
- 3 x Inverter Gree AC 2 TON (2 ton inverter AC x 3 units)
- 3 X Inverter Gree 1.5 TON (1.5 ton inverter AC x 3)
- 2 fridge (Dawlance 16-18 cu ft)
- 1 deep freezer (Dawlance)
- One Espa pressure booster motor pump 0.75 HP (takes max 2 ampere when tap is open)
- 2 x 55 Inch Samsung LED TV
- One automatic washing machine 8kg samsung
- ceiling fans x 8
- 25 lights (10 watt LED bulbs)
My questions:
Please advise if this load is possible to run on solar and what will be the required solar inverter capacity and panels? I am thinking 20 KW inverter with around 25000 watt panels?
What brands would you consider for inverter? Getting 2 x 10 KW inverters or getting one 20 KW inverter. I am thinking about HUAWEI on grid inverter 20KW it is for around 350k. What are 20KW on grid good brand inverters?
Is LESCO offering net metering in DHA phase 2? is it an easy process to get the license?
What should be the estimated cost for that setup without batteries as i only plan to run it in day time on solar with no batteries.
Please recommend brands and any authorized companies that offer services assuring net metering approvals with your own personal experience. Would really appreciate your help guys.
