Dear V2 users
Please help me out on this. My v2 is showing strange problem. Its is only starting once after multiple attempts. In addition to this the central locking is also showing problem and getting unlock as soon as I lock the car from key.
How is the battery condition ?
Battery is at 10v check from obd..
Get the fuse box checked. Last time a friends V2 central locking wasent working at the end the fuse was fried.
Central locking is working but reversing immediatly
A faw representative told me to sit in the car and lock unlock three time via key.. It worked once but not working now
Looking for response from experienced V2 users
10v is very low. When the car is not on, with the switch set to on, it should be at least 12.5V. When the engine is running, without any load, the voltage should be 14+V, and with full load, 12.5+V. I would suggest you to get your battery checked.
Thanks everyone
The battery was at 10v and dropping even further during self. The battery has been replaced with new and problem get solved.
