Salam Guys,
i have been facing AC issue for last 2 -3 years on my 2007 Vitz (2nd Generation). when i turn on the AC it the switch in the light turns green, Radiator fan starts and car revs up as well but there is no cooling but if i try this after 5 or 10 minutes then AC starts cooling and performance is great as usual but then after tripping it doesn't start again and i have to try it manually and it starts cooling. i got it checked and they said its because the compressor is faulty and i need to change compressor and condenser and gets pipe cleaned.
moreover they will not fit original compressor as its expensive so they will install some other compressor which will need some alterations as well.
so my questions is has any one else face this kind of problem or has any one else change there compressors or condenser? would help if some one shares there experience.
Thank you.
