Enjoy Pakistan’s Largest Data Maps with Extensive Dataset & Detailed Data Maps of Pakistan exclusively provided by Tracking World.
• Exciting Features of Tracking World’s Navigation Map
• Offline Map of entire Pakistan
• Housing Address Search in all Major Cities of Pakistan
• High Definition 2D & 3D Landmarks with over 4 Million Point of Interests (POI’s)
• Coverage all over Pakistan
• Voice guided Navigation
• Alternate routes & Multi-stop route planning
• Detailed Locations available
https://www.4shared.com/zip/4W3TlNo5fi/TWNav_100981__pkcomtrackingwor.html
- Download TW Nav ANDROID.zip folder
- Extract on PC(you will get TWNav 10.0.981 (pk.com.trackingworld.twnav).apk & Android folder)
- Copy both on Android Unit (may be initially at download folder)
- Now Install TWNav 10.0.981 (pk.com.trackingworld.twnav).apk
(Since your phone considers any application outside of Google Play an "unknown app", you need to tell your phone to allow you to install unknown apps.
ENABLE INSTALLING "UNKOWN APPS" ON ANDROID
Go into Settings
Tap Security
Scroll down to the Device Administration section, and enable Unknown Sources.
Go to Settings
Then Apps and Notifications
Select Install Unknown Apps (or Install Other Apps).
At the End. Copy pk.com.trackingworld.twnav from Android Folder in Main Storage
Path is
Android/data/pk.com.trackingworld.twnav
