Don't worry, the affected models were from the beginning of production to February 2014. Later models were revised so you don't have to be worried. As for pre Feb 2014 models(like the one I have) are fixed by Honda in Japan if they're imported on the later date. My car had the recall but it's fixed from Honda japan. The way to know if your has had a recall fixed you need to see the door jamb(driver's side),you'll see stickers that correspond to each recall. As for overheating issue, it's because of people not knowing the maintainence of these things, there's a transmission fluid (atf) and then there's a brake fluid (dot4),more commonly known as clutch oil in Pakistan, just change that and you're all good to go
