You will have to do a complete intake to exhaust swap as 1.5 JDM engine has multiple o2 sensors and catalytic converter. ECU wiring for these sensors will also be required. The engine mounts may be different so those will also be replaced. Possibly transmission/axles too. If you miss out anything the car will not run to its full potential and you may get mileage/performance issues.
